Is a Dumble ODS keyboard amp possible?
I would like to know if it would be possible to make an amp that would take a wider range of frequencies?  I play guitar with midi pickup +synth, and have an effects loop in the guitar like Jerry Garcia.   Some of the synth patches have low bass, and I have heard that bass is bad for guitar amps.  I would like to not have to worry about destroying my amp.  Any help? All input welcome.
						Re: Is a Dumble ODS keyboard amp possible?
would the pre-amp out work if connected to a power amp?
I'm not sure I understand your question. The Dumble should produce plenty of highs and lows for your needs with the right speakers, but why would you want a tube amp for keyboards? Just use a good solid PA.
						- David Root
Unless it's a Hammond B-3!
						actually...
I do have one plugin for the B3... so yes that's one midi synth I will be running through the amp
