Hi Guys,
When we first get a new amp going it is customary to measure the voltages so we can determine if everything is correct or where it should be.
I took an existing chart and edited it a bit to fit our requirements.
It's good to record the voltages along with the wall voltage as a reference so that later on if there is a problem we can compare those voltages to the
chart.
You can fill it in with Paint or print it out and do it manually.
I'm not good enough at this stuff to make one that is editable.
Enjoy!
						Voltage Chart
Voltage Chart
Re: Voltage Chart
No sorry, I don't think I have that capability.
That would be nice to be able to sticky it.
excel sheet
Here's a version of an Excel one I started and never completed. I was going to have it auto populate and linked to another inventory sheet , but I never finished it. You can use it as is for just a simple log. Eventually, I'll get around to another with all the bells and trinkets.
TM
						TM
						Re: Voltage Chart
For those of you who use ExpressSCH, you can find an editable voltage chart attached to the 10th reply on this thread:
http://www.el34world.com/Forum/index.php?topic=9498.0
You can easily edit this for a D-clone.
With respect, 10thtx
