183 Build Clip
183 Build Clip
Here's a short clip of a 183 build I recently completed. I'm really happy with the way this amp turned out. Hope you like it.
http://soundclick.com/share.cfm?id=11313562
Cheers (and Merry Christmas!)
Brian
Brian
Re: 183 Build Clip
Great tone and playing Brian.
What guitar did you use?
Do you run a Dumbleator?
Re: 183 Build Clip
Really like that, very smooth with just enough articulation.
						Re: 183 Build Clip
Thanks gents!
Has a loop, but not a classic Dumblator, rather, a SS loop of my own design - not unlike an IronSounds but with filtering to emulate Dumblator coloring. Using on board reverb based on a SPIN Semi DSP.
Guitar is a Godin. Cab is a 2X12 oval open back with Emi DeltaPro12As.
- boldaslove6789
Re: 183 Build Clip
Sounds really great!
									Greg D.C.
Can you dig it?
						Can you dig it?
				bluesfendermanblues
Re: 183 Build Clip
+1boldaslove6789 wrote:Sounds really great!
				telentubes
Re: 183 Build Clip
Sounds great!
						Re: 183 Build Clip
It does sound awesome.
						Re: 183 Build Clip
Hi Brian,
Sounds Great! Would you enlighten us on the use of the spin reverb? I am contemplating incorporating a similar OCT FV-1 based reverb - yet to purchase- and am having a little trouble getting started in the right direction such as what is required for a carrier board and how to mix the reverb into the loop (signal levels ets).
Any hints, tips etc would be greatly appreciated.
Thanks!
Thanks!
Re: 183 Build Clip
Re: 183 Build Clip
It's not a trivial undertaking but I can give you a quick and dirty tutorial...John_P_WI wrote:Hi Brian,
Thanks!
Two aspects of using the SPIN FV-1 chip:
Electrical interface of the chip to your amp.
Programming the effect algorithm(s) to run on the DSP.
I positioned the SPIN in the effects loop of my amp. Although it's inside the amp, you might think of it like any other effect. If you have an active loop already, you're at least half way there. You'll want to split the signal for a wet and dry path to maintain a pure analog dry path. On the wet side, the SPIN signal interface is requires that you attenuate/limit to a level of 3.3V P-P maximum and AC couple it into the SPIN chip. The signal return then needs gain recovery applied. I've found 20dB attenuation and recovery seems to work well with my builds. You need about 100mA of well regulated 3.3VDC power for the FV-1. You can derive this off the heater supply (with great care!) or use the relay supply. The FV-1 is only available in a surface mount package so you'll likely need to do a custom PCB (and all the grief that goes with doing your own surface mount production). An alternative (I think this is the way Gary has gone) is to use a SPIN board that OCT Distribution is making: http://www.oct-distribution.com/
SPIN Semi provides free PC tools for programming the SPIN and there are a good number of sample programs to get you well on your way to doing your own effects. But none are suitable for use without some alteration and tweaking. So get ready to bite the bullet and start learning how to program in the FV-1 assembler language and how DSP algorithms in general are designed (an Engineering degree is an asset!). You'll also want to buy the FV-1 Development board as this gives you a convenient platform to load and test your DSP effects algorithms from a PC and program EEPROM for storing your code in proms for running on your target board.
Hope that helps!
Re: 183 Build Clip
Sounds great, Brian. The amp and the playing
						Re: 183 Build Clip
Brian
Sounds good man
 Keep up the good work!!
									Sounds good man
