	Moderators:  pompeiisneaks , Colossal
								markusw
		Posts:  475 Joined:  Tue Sep 26, 2006 5:10 pmLocation:  Vienna/Austria
						Post
								by markusw  Tue Dec 06, 2011 1:34 pm
			Thanks for sharing!
Great sound and playing!
Do you have more clips?
May I ask one question: is it really 2-4 µF (not nF?) from EL84 Anode to gnd?
Peace,
Markus
								hywelg
		Posts:  92 Joined:  Mon Apr 14, 2008 9:08 pmLocation:  Nottingham UK
						Post
								by hywelg  Tue Dec 06, 2011 2:07 pm
			This is really interesting. I had been hoping that something like this would come along, but had just about given up. I was intending to get one of these
http://www.ampmaker.com/store/Double-Si ... ifier.html
and had been thinking about how to add in an o/d section.
Since I'm not terribly knowledgeable about things electronic, and I've only ever built kits, a scratch build is probably beyond my abilities, but I think I could just about manage to do something like this especially if I could use the output section of the Double Six kit.
								honeydip
		Posts:  28 Joined:  Sun Oct 29, 2006 10:20 amLocation:  Northern Germany
						Post
								by honeydip  Tue Dec 06, 2011 6:34 pm
			Markus, you are right it's 2 to 4nF depending on your Taste.
									No distortion means to tone.
								stiltamp
		Posts:  84 Joined:  Sun Jun 11, 2006 6:11 pm
						Post
								by stiltamp  Tue Dec 06, 2011 11:34 pm
			Thank you for the information.
The PT I have taken out of an old Radio
How much is the secondary HT Voltage value of it?
								markusw
						Post
								by markusw  Wed Dec 07, 2011 10:53 am
			honeydip wrote: Markus, you are right it's 2 to 4nF depending on your Taste.
If you happen to have the chance to record a clip with Strat that would be great.
One more question: how do you like the tone control of the clean channel when in OD?
Thanks again for sharing your work!
Regards,
Markus
		Posts:  15446 Joined:  Wed Oct 17, 2007 1:01 amLocation:  Oregon
						Post
								by Structo  Wed Dec 07, 2011 3:13 pm
			2-4µF on the cap on the EL84 plate to ground.
								10thTx
		Posts:  1872 Joined:  Sat Dec 30, 2006 1:13 am
						Post
								by 10thTx  Wed Dec 07, 2011 3:52 pm
What does that mean?
Per earlier post request,  ............... I already changed the schematic to reflect a .002-.004 cap from EL84 plate to ground?
What should it be?
With respect, 10thtx
								honeydip
						Post
								by honeydip  Wed Dec 07, 2011 4:12 pm
			I'm sorry, you are right and I was blind
The schematic is correct.
Thank you.
Honeydip
								10thTx
						Post
								by 10thTx  Wed Dec 07, 2011 4:32 pm
I am understanding this to be that the
currently posted  schematic is correct?  I changed it to the current one
after  you requested me to do so.
Just post a reply if it needs to be changed from the current schematic, otherwise, I will presume it is currently correct.
Thanks, 10thtx
						Post
								by Structo  Wed Dec 07, 2011 6:11 pm
			Oh Snap!
								wicker
		Posts:  182 Joined:  Thu Oct 01, 2009 6:43 pmLocation:  Poland
						Post
								by wicker  Wed Dec 07, 2011 8:23 pm
			Structo wrote: Us Yanks aren't used to nano farads so much as micro and pico.
I've noticed that, I always did not understood why the hell, instead od 0.1u couldn't be 100n
Paul
								alvarezh
		Posts:  461 Joined:  Thu Oct 18, 2007 11:11 amLocation:  Santo Domingo, D.R.
						Post
								by alvarezh  Fri Dec 09, 2011 2:53 pm
			Nice sounding little amp, thanks for sharing. Thank you 10thtx for the drawings.
									Horacio
								10thTx
						Post
								by 10thTx  Fri Dec 09, 2011 4:18 pm
			Go with the schematic which should be correct.
								alvarezh
						Post
								by alvarezh  Fri Dec 09, 2011 4:33 pm
			Thank you for clarifying 10thtx, and thanks again  for taking your time to make the drawings.
									Horacio
