I just feel that I could free up some space loosing that recto tube and also go with fixed bias. I really like a lot of my cathode 6L6 builds but..... I always have to do things differently it seems
 I can relate to that. I've never cloned an amp.I always have to do things differently it seems
Will do,I hope you'll post how you like the amp and link soundclips if you make some.
 Correct, it is a pot that can go on the front.this is a pot not a trimmer right
IF I am understanding this question correctly, the DPDT is a on-on allowing either clean or OD.mini DPDT switch is on-on-on? Switching OD in and out but allowing the signal to flow through loop?
 I always like to start with a faceplate so I am working on that.  I saw Berry's (bnwitt) faceplate but I am going to make mine a different layout.  He doesn't post here much anymore.
  I always like to start with a faceplate so I am working on that.  I saw Berry's (bnwitt) faceplate but I am going to make mine a different layout.  He doesn't post here much anymore.You'll need 3 preamp tubes, LTPI, and power tubes.Only bummer is having to drill out another tube socket. Is the fatness tube really really necessary
