Resistor on output jack
Re: Resistor on output jack
Not exactly what you guys are talking about but I belive peavey used diodes from the plates to ground.to protect the OT no-load situations.
I do fear pudding-headed friends blowing my OTs, though I too have rarely seen it happen, but I've been looking for a good solution. Unless someone chimes in with some negatives (aren't there always negatives?) with using ~200R on the output jack I might start retrofitting my amps. BillyZ says he couldn't hear it, that's word for me.katopan wrote:I put a 270 ohm 5W resistor permanently soldered across one output jack (always used the 8 ohm jack) on all my amps. Transparent compared to the speaker load as mentioned above, and stops any flyback voltage spikes killing the OT if no speaker is connected.
Most of my amps already have a B+ fuse (after the rectifier not OT CT) so as rooster says is the output resistor just belt and suspenders?
BTW I find a B+ fuse to be a pita on ss rectifier amps. The power-on surges fatigue it too quickly so the resistor trick seems more applicable.
Here is a scan of the Traynor power amp and OT showing the resistor. I was wrong it is 180 ohm 20w. The one I saw was standard looking cement box type.
Scroll down thru the pages to find it on several schematics.
Billy, thanks. I'm going to order some chassis mounts types for the amps friends like to borrow. Seems to good to be true, why doesn't every builder do this?
Cost money.rp wrote:Billy, thanks. I'm going to order some chassis mounts types for the amps friends like to borrow. Seems to good to be true, why doesn't every builder do this?
