Structo wrote:Anybody know how you would calculate an HT fuse size?
It is my understanding that on commercial amps they would be tested in specific fail modes to ensure the fuses work correctly.
For most people, looking at existing commercial amps that you know have been tested is the quickest way to get a baseline. i.e. Marshalls and Fenders etc
I can't advise on a method for calculating them
You also need to make sure you use flameproof resistors in your filter section, as a short after most of these will cause the power dissipated to far exceed the resistors wattage rating and the HT fuse will not protect it.
i.e. a 10k Resistor with 350v across in a fault situation will have 0.035A going through it, not enough to blow a typical HT fuse, but the resistor will be dissipating 12W!!!  FLAMES
