A few updates including schematic...
I cleaned up the wiring as best I could, looks a lot cleaner now. Put in a Sylvania NOS 6SN7. Way way better.
I put a 330k on the 1M MV pot's outer lugs for ~250k total. I also added a 1k grid stopper to the EL34, but I think that is going to come back out because it seemed to lose a little bit of dynamics.
Unfortunately that burned B+ rail resistor scorched my board. I didn't try it yet but I'm hoping some rubbing alcohol with a q-tip will clean some of that up a bit. If anyone has any tips I would appreciate that.
I didn't move the MV pot either, because I might add a presence control to the amp between the treble and grid of the next tube. From what I understand I can do a 22k/3n/25k series to ground here. So I wanted to leave the hole where it was because its in perfect position to do this and the MV has to run over the board to get to the EL34 anyway, so in either spot it wouldn't matter. I made the runs shielded.
The other thing I might do is put the 56k Rk on the tube CF on a switch to go from maybe 100k to either 56k or a value a bit higher. Seems it might be affecting the cleans just a touch. At guitar volume on 7 it is still somewhat clean but not quite. I am thinking the added compression at this stage is preventing it from getting cleaner. Turn it up to 10, she's got some gain for sure.
The NFB NA/5k/10k switch is subtle, I was going to just take it out but decided to leave it in as it isn't making things noisier or anything. If I was doing this amp again from scratch, I wouldn't bother with it.
The GS before this CF has its Ck on a switch to switch it out or in. Very useful. Kind of a HB/SC switch.
All in all there is no hum audible until its at about 8 on the MV. At 10, she's still very quiet. Sounds very nice.
[img
877]
http://chicagocadcam.com/ChrisHahn/supr ... ual_v3.jpg[/img]
