Build Complete Marshall 18W Head
ToneMerc
Post by ToneMerc »
Just started another build which is a Marshall 18W head. This one is a tad different as I was never fond of that stock layout with all the flying coupling caps. This layout has all the caps on board along including the HT fuse and a cut control.
Heyboer Trannies
Stu Daddy 18W chassis & plates
JJ tubes.
TM
Lonely Raven
Re: Build Complete Marshall 18W Head
Post by Lonely Raven »
Hmm, sounds interesting!
I have an 18 watt I got second hand (not very well built) and has issues. So I'm interested in seeing what you do since I'm considering rebuilding mine from the chassis up.
Jack of all Trades,
Master of None
dcribbs1412
Post by dcribbs1412 »
Nice looking chassis and board TM
extra cliff jack for a footswitch?
Darin
ToneMerc
Post by ToneMerc »
dcribbs1412 wrote:Nice looking chassis and board TM
Darin
Thx Darin, yep for the tremolo.
TM
ToneMerc
Post by ToneMerc »
lil more
ToneMerc
Post by ToneMerc »
The perimeter wiring is almost done.
ToneMerc
Post by ToneMerc »
A little bit closer to the finish line.
TM
Nice progress. Nice work.
One thing, just a point of curiosity really and not at all a criticism, about the placement of V3, v4, and V5, did you buy the chassis already punched?
If I were cutting the chassis, I think I'd prefer to have those sockets a bit closer the board and away from the jacks and other stuff you have on the rear face. I consistently find this to be a difficult thing to plan for. Holes get made on the outside before you start attaching parts. This is a big part of the challenge. Also, I can't see the top side. Maybe the OT get in the way, too. There are always compromises.
ToneMerc
Post by ToneMerc »
Phil_S wrote:Nice progress. Nice work.
Yep it was already punched, the tube sockets screw holes are normally indexed at 1 & 7' o'clock as well. However, $50 for a new chassis including both front and rear plates was too good of a deal to pass up.
TM
TM
Agreed, a great deal. Work with what you got. I realize, there should be adequate vertical space above sockets 3-5. I just don't like to sacrifice the air rights, though I often have done it. Looking forward to seeing the finished product. Good luck with it.
Very nice looking build.
ToneMerc
Post by ToneMerc »
Phil, it's typical of the layout/spacing found in most of the 18W prefab chassis's. Here another inside view and one from topside as well. I have to install a few more resistors, tremolo oscillator caps, the nor chan input jacks and it will be done.
TM
ToneMerc
Post by ToneMerc »
Ok, all done except tacking in a 125-150 cathode resistor.
TM
Colossal
Post by Colossal »
Great job TM! What speaker will you be trying it with? Are those all carbon comps?
ToneMerc
Post by ToneMerc »
Colossal wrote:Great job TM! What speaker will you be trying it with? Are those all carbon comps?
Thanks Colossal
I got lazy and half cocked the power wiring lead dressing, but overall I guess it's not too bad. I think this layout is much better that the original with those flying coupling caps and this layout has a HT fuse as well. The cut control was a last minute addition because I saw some daylight on the board. If I could do it all over gain, I would install a mini switch so that I could disconnect it.
An open back 1-12 with a Vintage 30.
Well, it's mostly all Piher CF that you see. I used Allen Bradley CC in a couple locations because I didn't want to deplete my Pihers in those values.
TM
