JTM45ish build
dcribbs1412
JTM45ish build
Post by dcribbs1412 »
JTM45ish build, misc parts...my first try at face-plates...
not sure it's worth the trouble.
Got it mostly done I think
just have to recheck everything and start power up process
hopefully this weekend...
any comments/suggestions are appreciated
Darin
pics
Re: JTM45ish build
Darin looks good :)
For faceplate did you use clear label tape and then cover with clear plexi?
Home made boards and MC iron should rock your house! :lol:
dcribbs1412
Re: JTM45ish build
Hi Mark
used clear plexi and clear water-slide decals then painted silver
not sure it will hold up... it wasn't too hard...just a little time consuming
turned out OK nothing great hopefully I'll get better at it in time
really what to start getting builds into head cabs...
easier to stack up :wink:
Home made boards and MC iron should rock your house! Laughing
I hope so...
I'm hoping to be able to run it through a 1x12 cab and get decent tones
going to run it into a Tone Tubby Alnico and see.
Darin
plexitone
Re: JTM45ish build
Post by plexitone »
Nice job. One minor suggestion: Lift the green grid wires up away from the chassis and heater wires to help reduce hum.
dcribbs1412
Re: JTM45ish build
Thanks plexitone
will do ASAP
Darin
Re: JTM45ish build
Your probably going to need at least a 212 for that bad boy.
Re: JTM45ish build
Man, that looks really good Darin.
You certainly have some neat NOS parts there.
Hopefully the m0jo will come forth.
So on the decals, you applied them on the back side?
Then sprayed silver paint over the top?
dcribbs1412
Re: JTM45ish build
Thanks Tom
the mustards are 18n(cheaper than the 22's) and all measured on my meter at 20n...hopefully close enough for the Mojo...
Correct I used Word for the labels and flipped it horizontal
so it printed backwards
and then applied the decals on the back and painted over them with silver paint. It's a start...pretty cheap I hope to get it better after a few more
makes me want to get it in a head cab...
Darin
Re: JTM45ish build
So have you powered it up yet?
dcribbs1412
Re: JTM45ish build
Hi Tom
Work has been kinda crazy this week and its almost "beer thirty"
Really want to power it up but I want to do a good "sober" check first
gonna use the bulb limiter and take it slow
hopefully this weekend I'll get it going
Darin
tubeswell
Re: JTM45ish build
Post by tubeswell »
Those face plates look pretty damn good
statorvane
Re: JTM45ish build
Post by statorvane »
Ditto. Nice job there. Good luck powering it up.
EDIT: What power tubes are you going to run in there?
Bob S
JTM45
Post by Bob S »
Wow - Nice build.
This is definitely on my to-do list.
Good Luck with the start up.
Why Aye Man
dcribbs1412
Re: JTM45ish build
Thanks guys
I wish I had the room for a 2x12
got a pair of Valve Art KT66 for power tubes
I've got 2 more Dumble-style builds to do....Gonna see if face-plates will work.
Darin
ToneMerc
Re: JTM45ish build
Post by ToneMerc »
Nice work Darin :)
TM
