Rocketus Addus Reverbus
Re: Rocketus Addus Reverbus
I changed the wiring in two of my Rocket Reverb amps to shielded wire off the tube to the RCA this took the noise away from both amps.
In some cases it may be necessary to add shielded wire from the other triode to the entrance of the PI as well.
My Rocket
I am looking for the EL-84  version on this and will post my current build layout w/ 1/2 power and VVR. My cabinet is quite tall so I should benefit from this info regarding the verb tank... thanks. Seems like it will be pretty straight forward. Have not had my hands on the solder iron for a while, but i do want to transition my amp to a reverb model.
best ange
						best ange
Ange did you get the reverb pan number and driver number?
Accutronics 8AB2A1B (short tank, medium delay) or MOD version Korean made black in color
Hammond 1750A reverb tranny or similiar spec reverb driver.
80W Rocket Reverb
Mark,
Did you ever work up a schematic for that 80 watter you built. I would love to build one myself.
If so would you mind sharing it?
sst4270@verizon.net
Sincerely,
Steve
Also if you've got any more detailed gut shots. I would love to see them as well.
sst4270@verizon.net
Sincerely,
Steve
Steve I did not make a schematic for that amp.
Edcor 100w PT 300-0-300 400mA 6.3ct 10A
Edcor OT 100w rating 3k3 4/8/16
Hammond 158L choke 15H 75mA
Mojo 776 (989 0949) reverb driver
You can use others like the Hammond 1750A reverb driver also
Uses Normster's tone board. The only addition is a mid pot, bright switch, and gain boost switch (10uf/25v cap from V1b cathode to ground).
short reverb pan (mesa/Boogie) 8AB2A1B
input impedance - 10 ohm
output impedance - 2575 ohms
decay time - medium (1.75 - 3.0 sec.)
The power supply layout was my own which can be built to suit your need.
I need to finish the front valence and make a new faceplate this amp was make by gutting my Express 100 which I could not control to make this Rocket. All new parts used only the faceplate and chassis were used. My hat goes off to Allyn Meyer for building his great 80w Express, I couldn't.
Here is Normster's layouts and Allymey's Express 80.
Rawnster has a good layout and schematic if he wants to share otherwise it is posted on here on TAG.
That's funny... I was the one who created that Layout of Allyn's wreck after he posted all the gut shots.
I'm surprised you didn't go with the external bias adjustment on yours like he did.
Thanks for posting those alternative layouts of Normster's stuff I only had the one.
Steve
Steve
I did use the Bourns bias locking pot on the Express build but decided not to on this one.
Steve you should be able to produce another fine layout for this amp then
Mark,
I definitely will! Send me those gut shots when you get a chance.
Steve
Steve
Here's my schematic of the Rocket preamp, KT-66 power section, and reverb.
						- dorrisant
rj,
i know this thread is a little old but i did find another error on your reverb schematic... i believe the plate/anode voltage from the reverb transformer should not be connected to V6-5... would blow the filament there... maybe V6-6 along with V6-1. i know i've missed this a few times myself... not just your eyes... or maybe mine are all screwed up right now
oh yeah... did you omit the "direct out" from the schematic for a reason? i was thinking about trying it out and was just wondering why its not on the reverb schematic... how well does it work?
tony
tony
- RJ Guitars
Yes the thread still gets a little traffic and the amp has enjoyed a steady following over the past few years. I think there must be about 25 to 20 of them out there now and several more from the real DIY guys who didn't use me as a parts supplier.
I had seen that pin number was wrong before and it was fixed in the master drawing but apparently I hadn't posted that into this thread.
I decided to move the documentation drawings from the 2nd page of the thread and add them to the original post on page one because history has indicated that it makes it immensely easier to find and refer to the layout and schematic drawings.
I did leave what I think is a decent rev. of the original layout drawing since I don't want to take away the education that went along with this project. I don't use that same layout on the Rockster amps I build or kits I sell but a later derivative of it.
Thanks for the heads-up... that is why those schematics and layouts ofter have a "Draft" or cautionary note on them. Take that to heart if it doesn't say something like tried and proven design although this one is getting pretty close these days.
rj
rj
http://www.rjguitars.net
