I replaced the big red cap in the gut shot with a 40uf one and also replaced a couple of the resistors in this pic. I replaced the 70/40/40 cap can as well.
Now, the amp sounds a little better, but voltages are off. The OT was buggered up by whoever installed it. A very poor job of connecting new wires to the OT is hidden by the electrical tape, and the OT was hanging by one bolt. I mounted the new OT in the original stock location.
I purchased a replacement OT (http://www.triodeelectronics.com/tf65wscta48o.html) and this is the wiring diagram ([img
I've replaced the OT, and I wanted to double-check here to make certain that my reasoning is sound regarding the wiring. A schematic is attached. As a side note, I also installed a 3-prong plug and will pull the death cap.
1. The brown and blue plate leads go to Pin 3 on V1 and V2 respectively 7591 tubes, http://www.duncanamps.com/tdsl/show.php?des=7591).
2. Black goes to ground.
3. Green goes to the 10k resistor adjacent to the large 140 resistor, you can see it in the gut shot coming out of the small hole between the two power tubes. It appears at junction A at the bottom of the schematic. Or, does it go to the speaker jack, or both?
4. Red goes to the 70uf cap.
Now, I'm left with the two leads marked Screen on the OT diagram. The old OT didn't have these leads, so I'm trying to locate their connections. Or, they may not be used at all, which is what I'm thinking.
I also used one of the existing vent holes in the back of the chassis to mount a speaker jack (non-invasive mod). I'm a bit confused on the green 8ohm speaker lead. In the schematic and other pictures I've seen, the line looks like it would go to the 10k resistor I mentioned above. If I wire it that way, do I need to run a wire from the 10k connection to the jack, or where should the jack be connected? Do the screen leads need to be connected, and if so, where? Alternatively, should the green and black wires run to the new speaker jack as in other amps I've seen?
Thanks for helping!
