I used some clips that wraps around the edge of the chassis "lip" and put screws through that.
How do you do it?
Tommy
						How to bolt the chassi to the cab?
Re: How to bolt the chassi to the cab?
I had the chassis made with strips that were welded in and then tapped out, so that I can just pass the bolt through the head cabinet and thread directly into the chassis.Tdale wrote:I used some clips that wraps around the edge of the chassis "lip" and put screws through that.
How do you do it?
Tommy
Tempus edax rerum
I have been doing the same. I am using clips for 1/4 bolts and I drill the chassis hole a little bit larger. The clip hold in place pretty well but can move a little so it kind of self center when you thread the bolt in.Tdale wrote:I used some clips that wraps around the edge of the chassis "lip" and put screws through that.
How do you do it?
Tommy
Cage nuts are a nice alternative but they require a square hole.
I got some cage nuts today. I was thinking about a different way to install them. In stead of making a square hole, to put it through, how about sawing two very narrow slots, to slide the cage nut into, and then just drill a round hole.. It would work, but I'm afraid it might weaken the chassis too much..
Tommy
						Tommy
