Hello Everyone,
Your forum was suggested to me by a fellow member. I have to say that I really dig this place. I would like to learn more about tube amp circuits, could you suggest some books for me to read to get started. I've always been on the other side of the bench, I would like to change that. Any information would be greatly appreciated.
New To The Forum
Re: New To The Forum
welcome! (from a relative newcomer, as well)
This place is full of very knowledgeable people who are more than happy to help. Another forum where you also might want to sign up (if you haven't already) is www.18Watt.com. Both there and here are free from the garbage and vulgarities easily found elsewhere. It's all about amps, and all about learning.
Welcome!
If you have not already done so, there is a lot of stuff you can learn from different web sites, like the technical section of http://www.aikenamps.com/ and the FAQ at http://ax84.com
You can also read:
http://www.pacificrecone.com/JackDarrBook.html
http://www.radau5.ch/basics_1.html
Or buy one of the book from Kevin O'Connors http://www.londonpower.com/
You can also read:
resophonic1
Thanks for the information!
oldhousescott
Two more sites, in case you get bored......
http://www.pmillett.com/technical_books_online.htm
http://www.tpub.com/neets/
Hope this helps
Hope this helps
"We put a little quality in everything we build..."
