vibratoking wrote:I can buy and install alot of VVRs for a thousand bucks.  And I can then use them together in a multi amp setup.  With the attenuators, I basically multiply the number of amps I want to use by the cost of each attenuator.
All true, but VVR isn't a universal panacea either, needs to be beefed up to work in a 100W amp because the MOSFET's going to have to dissipate a massive amount of heat, particularly at -6dB.  And you're unlikely to want to retro-fit it to anything vintage for fear of affecting its value.
vibratoking wrote:The sound is better and the investment is much less.
I'm going to wholeheartedly disagree on the sound front.  If you've got a circuit that has power supply compression caused by the limitations of the power transformer regulation (and we know that most have pretty poor regulation because the original specifications were all about making them cheap) then you'll lose this part of the equation as you turn down the volume.
Now, whether the tonal alteration of any given attenuator is more or less significant than this is open to debate, but VVR is not completely transparent as it can't defy basic electronic theory.
Don't get me wrong; I like VVR. But I also appreciate its practical limitations.  And if these limitations didn't exist every manufacturer would be putting it in their products to get round the problem of wanting 'that tone' at all volumes.
