2rd Gen 100W hybrid completed
ToneMerc
Re: why
Post by ToneMerc »
angelodp wrote:Mike, why did you decide on #40?
Ange
Well, 2 years ago when I started to search for period correct parts , #40 was one of the more visually documented of the type. However, outside of the preamp board, i'm using some values in other places that are actual values taken from an amp in the same range of S/N's.
Mike
Re: 2rd Gen 100W hybrid completed
ToneMerc wrote:
Structo wrote:Looking good TM.
Are you going to use a film cap for the presence?
I finally installed my FET board yesterday! :lol:
Thanks Tom,
Yeah I debated whether to install a tant or not, but in the spirit of the build I went ahead and installed a fim cap. It worked out because I just happened to have some large values orange film cap.
How do you like the FET? Did you use the stock cap values?
TM
I had a bunch of notes I collected about the FET and I used Jason's FET board.
I did change C3 to 22uF and the input ceramic to 470pf.
Hopefully the 22uF won't be too large but I wanted it to bypass full range.
The 470pf is supposed to flatten the high end a bit.
I wired in a pot for R3 and R5 to dial in the bias voltage and supply voltage.
I ended up with a 1.5K for R3 and a 20K for R5.
Weird but that is where I got the 20v and 10v.
But my dropping string is also different from the Dumbles.
Everybody's amps are probably different as far as the FET bias goes.
ToneMerc
Post by ToneMerc »
I'm in the last mile now, only a few outstanding tasks left.
1. Wire up mid switch.
2. Run 3 strands of coax.
3. Install PT and wire it up.
TM
angelodp
irish?
Post by angelodp »
Mike, its a beauty, it has a kind of Irish color scheme or is that Xmas!!
Ange
ToneMerc
Re: irish?
Post by ToneMerc »
angelodp wrote:Mike, its a beauty, it has a kind of Irish color scheme or is that Xmas!!
Ange
Maybe, I just happen to be sitting down drinking my fav brew at the moment, Smithwick's Irish Ale.
Thanks Ange
Mike
David Root
Post by David Root »
Tom, Mike, I use NTE 452 in my FETs and I find 22K and 2K5 works pretty close.
Ahhhh! Smithwick's an excellent brew! One of my faves too!
angelodp
Colors
Post by angelodp »
Partial to Guinness myself. Cheers!
ToneMerc
Post by ToneMerc »
David Root wrote:Tom, Mike, I use NTE 452 in my FETs and I find 22K and 2K5 works pretty close.
David, I have a 2N4416A on this board with 2.2k and 22k resistors. I'm hoping this will get me close. The only other real changes are a 120pf cap and 10uF source cap.
Mike
ToneMerc
Re: Colors
Post by ToneMerc »
angelodp wrote:Partial to Guinness myself. Cheers!
Ange,
I like the Extra, but it has to be real cold for me to drink it. I don't like the taste when it starts to warm up.
angelodp
Just cool
Post by angelodp »
I like it just cool, like they do on tap around Dingle .... hahah !! Oh, with the bishops collar of course.
ToneMerc
Post by ToneMerc »
Truck just dropped off my head cabinet, hopefully I can button this up the next day or so.
TM
groovtubin
tonemerc
Post by groovtubin »
How bout some clips of this beauty?
Shame to see it and not hear it! :lol:
angelodp
beauty
Post by angelodp »
great cab....who made it for you.
ToneMerc
Re: tonemerc
Post by ToneMerc »
groovtubin wrote:How bout some clips of this beauty?
Jim, the plan is to put some slide and lap steel clips :wink:
Mike
ToneMerc
Re: beauty
Post by ToneMerc »
angelodp wrote:great cab....who made it for you.
Stage Craft Cabinets, great folks to deal with.
Mike
