ROCKET layout
ROCKET layout
Are there any more ROCKET layout out there with just two EL84s? The only one I can find is the A0 version that has four. Thanks, Andrew
pureoldsound
Re: ROCKET layout
I think thre are two layouts...Matts and Mark's. There are also so pics of other builds with different tweaks....
If I am not mistaken the two layouts that are posted, one is taken from a Two Rock Rocket and the other is basically is a mix of an express power supply with the Rocket's preamp...
Re: ROCKET layout
If you go with just two El84s then you will probably have to use a different output tranny also. Just drop 2 tubes and get yourself a 18watt 8k output tranny and use a 130 ohm cathode resistor
