The twin is an 100 watter, so sure, the 100 watt I am after. In all the files I have read so far this tonemaster PT shows up now and than, but nobody can answer for sure. I also know how much the draw is for the filament, but stranger things have happened in amp building. Only question nobody seems to be able to answer is if the tonemaster can be used and if it was at some point the PT in the "beloved" 183 amp. Even if nobody can be real sure, I am limited to the 102 circuit. But my preference is the 183 amp to clone (sort of).
Any way, thanks for every reply,
André
						#0183 Power Trafo
