HV Secondary Faux CT?
Cliff Schecht
One of my amp designs uses a 230-240V CT secondary. After FW rectification I end up with about 190 V for the plates of the power stage. I'm trying to recreate my prototype but I just realized that the custom transformer that Mag Comp sent me, as well as any other unit in my collection, all don't have a center tap. After FW rectifier (four diode style only) I'm at a higher voltage and lower current than I want to be at. Is there any way to create a virtual center tap for the B+ windings?
Cliff Schecht - Circuit P.I.
- VacuumVoodoo
Re: HV Secondary Faux CT?
That's not a virtual CT, that's a a hybrid silicon-tube bridge rectifier.
To answer original question: you can't make a virtual CT for the HT winding.
That hybrid bridge will drop some voltage depending on the tube type.
Aleksander Niemand
affiliation:TUBEWONDER AMPS
Zagray!-review
Zagray!-review
You can do it the same as Phil's pic just replacing the tube with 2 diodes, and no need for the limiting resistors. Lots of old radios that used selenium bridge recs did it that way too, and I've built a couple amps with recycled radio PTs, diode bridge and virtual CT..
Cliff Schecht
Bridge rectifier multiply by 1.414, current goes down too. Two diode fw rectifiers multiply by .707. In my case I need 190-200v so I use a 240v CT transformer or a 135v non-center tap. The sample unit Mag Comp sent me doesn't have a HV or filaments CT but does have a dual primary. I'll have to revise that PT design before I can use it.
Sorry, I see what your saying now. A bridge is unsuitable because it raises the voltage and drops the current, so you need to stick to a FW.
A virtual center tap like the 100R pair on a heater supply isn't going to work because it'll draw a whole lot of current at HV, unless you use values higher than would be allowable for max heater-cathode resistance.
One way to do it, kind-of, is a choke-input bridge rectifier. It'll get you a factor of about 0.9. With a 230VAC, you'll have about 210VDC, and about 50% more current than with a capacitor-input bridge.
http://www.hammondmfg.com/pdf/5c007.pdf
The downside is that you need to buy a choke that can handle lots o' current. And it will change the dynamics of the amp with a much stiffer power supply.
Matt
Matt
