a twreck build started - questions
- Guitar Adjuster
Re: a twreck build started - questions
Is there a difference between 22u and 25u that you can hear?
I Don't think so....but hey, who knows.
there is a difference. if u could hear it is another story. but again if yer trying to build to spec u use what is spec.
Rockstah Amps: http://www.rockstahamps.com
Rockstah Amps Youtube: http://www.youtube.com/user/RockstahAmps
Builds and modification sound files: http://www.soundclick.com/rockstahplexitweaksandmods
Most of these caps have a +/- 10% tolerance so the 22uf can be anywhere from 19.8 - 24.2 . Same thing with the 25uf, 22.8 - 27.2
It should be interesting to see if you can her any difference. Depending on the values, you could end up with the same value cap no matter which one you use
absolutely!UR12 wrote:Most of these caps have a +/- 10% tolerance so the 22uf can be anywhere from 19.8 - 24.2 . Same thing with the 25uf, 22.8 - 27.2
i want the 22u caps for the cathodes to make my build look the part.
