Dumble video/sound clip reference, real Dumbles only please
Re: Dumble video/sound clip reference, real Dumbles only please
boldaslove6789
Post by boldaslove6789 »
Ben Harper's Dumble's ( You can see Lindly's amp in the background)
Abbey Road Sessions:
http://www.youtube.com/watch?v=QitV6EFaYd4
Amp was discussed in this thread:
https://tubeamparchive.com/viewtopic.ph ... vid+lindly
Max
Post by Max »
Sonny ReVerb wrote:David Lindley, anyone?
http://www.youtube.com/watch?v=TAbbgSKUZB4
Guitar Player Magazine - September 1985:
"...after the last Steel-String Singer mod I did to David Lindley's amps,..."
http://personalpages.manchester.ac.uk/s ... e/Articles
Max
Max
Post by Max »
talbany wrote:
dogears wrote:Tony,
I believe those pics were taken by Doug R the amp builder who makes Marshall style stuff. The amp in the pics belongs to Ben Harper I believe.
Scott
Hope your well!
Yes the pics were taken by Doug Roccaforte and posted over at TGP.
A while back I posted them here and Brandon commented on who's amp it was
https://tubeamparchive.com/viewtopic.ph ... cannonball
and mentioned he thought it was used on the KOR CD..and thought it was used on Cannonball!!
If any of this is untrue be glad to change it..Thanks
Tony, Scott,
AFAIK this is #093 of Carlos Rios.
I think, that this amp is discussed here:
http://www.thegearpage.net/board/showth ... p?t=473990
It really looks like the "transition generation" ODS #093 built for Carlos Rios with matching open back cabinet.
Just a guess: This "transition generation" amp still has the "Accent" switch. Would it be possible, that the trim pot near the PI section on the board adjusts the amount of "accent" the switch provides and by this works more or less like some kind of internal "pre-set" presence control?
Here are pictures of Ben Harper’s "4th generation" #109 and Lindley’s "1st generation" amps:
http://www.fretboardjournal.com/photos/ ... id-lindley
On the front of the Lindley amps you find marks for the different settings for guitar and slide. Guitar settings are marked with a ring.
Here’s one more of these "1st generation" ODS (pictures from Bill Morgan’s "Treasures Of Equipment" site http://homepage.mac.com/bill_jpn_morgan ... lbum3.html ):
http://homepage.mac.com/bill_jpn_morgan ... 4%20II.jpg
http://homepage.mac.com/bill_jpn_morgan ... s/od50.jpg
AFAIR this "1st generation" ODS was used e. g. for the electric guitar tracks of this record:
http://www.audioty.com/sounds/marte.html
http://www.amazon.com/Angel-wings-Harry ... B003FPKR82
and this video:
http://www.youtube.com/watch?v=5d4elb_1MFE
Max
I love this description from the man himself:
It's a different kind of signal handling. In the Overdrive, I approach gain levels that are extremely intense; within the linear region, I have a signal gain capability of one million. So if you stuck 10 microvolts in, you'd get 10 volts back. And I do it with stability, and it's still very musical. The best way to approach an Overdrive is real slow. Walk up to it, look at the knobs, have it turned down real low, and then get a feeling for it. Learn what to do with your fingers to make it respond well. If you walk right up to it, it has a tendency to absolutely frighten some people. The secret control on the Overdrive's panel section is the ratio control, which controls how much overdrive is fed back into the circuit. If you turn that up, it's Rock City! :D
talbany
Post by talbany »
Max
Another cool post thanks.. Looking at the ring settings on the famous ROE amp (50w) and accounting for tone.. Those settings (w/switches) point to a strong indication that the stack values he used were 1M vol 1M treble and definitely a 1M bass (not sure of the middle but thinking 250K)This is pretty similar to how I run mine with singles and looks to be unmodded first generation... Also yep your right the trim pot is to control the amount of LNFB (Presence control)
Have a Great Day
ChrisM
Post by ChrisM »
Structo wrote:I love this description from the man himself:
What I always took away from that.
Was Dumble has a ton of potential gain on tap. However he is always attenuating it. Be that with the tonestack, volume, pregain, level, ratio, master. He is always killing signal so the tube's aren’t hit too hard. Hitting them too hard gets you into that nasty hard clipping metal territory.
Mesa and Dumble are very similar, for their timing and topology. Dumble just did some more refining and didn't go full bore like ol Randall did.
boldaslove6789
I finally got some pics of KirK hammets Dumble!!! It does NOT look like Srv's Dumble to my eyes. :D :D :D
Mac Daddy
#183
Post by Mac Daddy »
Demo by Mr Scott Lerner Non HRM EL34 Skyliner 100watter #183
http://www.scottlernermusic.com/dumble/ ... tLast2.mp3
boldaslove6789 wrote:I finally got some pics of KirK hammets Dumble!!! It does NOT look like Srv's Dumble to my eyes. :D :D :D
Soooo which one is it?
The one with the duct tape all over it.
For some reason I never picture metal guys with that kind of rack gear. :lol:
Re: #183
Mac Daddy wrote:Demo by Mr Scott Lerner Non HRM EL34 Skyliner 100watter #183
http://www.scottlernermusic.com/dumble/ ... tCSAgw.mp3
You guys ever figure out what made that amp stand out from the rest?
Have you ever tried 5881's or 6L6's in it?
I think Tag did but didn't like it.
Man, when I picture a EL34 amp, that isn't what I think of.
Really sweet.
I think what I liked about that amp was how it handled the low end without falling apart.
A very special amp. :D
Got any clips without backing?
Mac Daddy
Post by Mac Daddy »
I believe Tag only tried Nos EL34 Siemans and went back to the standard non Nos which are still in the amp , Only the pre amp tubes are nos
I believe GE's
http://www.youtube.com/watch?v=Yj0QfWezCTo
Max
Post by Max »
At around 4:00 RF talks about his 1982 "4th generation" Dumble ODS and you can see the settings he used to get the tones you hear:
http://www.youtube.com/watch?v=nBw_M2cQ ... re=related
Max
Max
Post by Max »
Structo wrote: Soooo which one is it?
Yes. Listen to "St. Anger". Here's some more info and some higher res. pics:
http://www.freewebs.com/montyjay/kirkamps.html#st.anger
http://www.amazon.com/St-Anger-Metallica/dp/B00008OWZG
Take care,
Max
Max
Re: #183
Post by Max »
Structo wrote:You guys ever figure out what made that amp stand out from the rest?
Your individual personal taste in perfect harmony with the individual tone, character, response,... of this Dumble ODS?
All the best,
Max
