Let us know how you like it.
Do you know what the spec is if you twist the two conductors together and use it as single conductor coax?
On my 50w amp I initially had coax from the Master to the loop jacks and back to the PI input.
It was the white 20ga Teflon from Apex.
I removed that and replaced it with single 20ga.
Seemed to lift a bit of dullness or mud from the tone.
I still have it on the four runs from the OD Drive and Level pots and on V1 grids.
									buying shielded cable
Re: buying shielded cable
mad_dog wrote:I'm looking at the coaxial cable from this guy on ebay
stores.ebay.com/QualityChinaGoods
He has RG174 that looks pretty cheap, would any of the other cables be ok??
I know I could get some stuff from Steve at Apex Jr but don't really need anything else and don't want to have to bulk up an order to make it $20 plus shipping to Australia
If you still need some coax, I also have RG 174/U and both 22 Awg
and 20 Awg PTFE wire 1 conductor shielded and I can send you
some at no charge .... Contact me thru a PM thru this forum.
Steve @ Apex Jr
I knew shielded cable had capacitance but I never worried much about it, I just knew not to go crazy with the stuff, but 70pf/ft is a lot - There's no way I'd just start soldering 50-70pf caps around the amp. My default has been to put it in where it should go, now my default will be to leave it out and see what happens and use the gs4 if needed. As long as I'm doing p-t-p I doubt I'll have trouble.
A question: If I disconnect the shield from ground will the capacitance equal that of unshielded wire?
As I mentioned I went a little overboard because I didn't know the effects of too much coax in my amp.
Now I only have it to V1 and on both runs of the OD Drive and Level pots. (4 runs)
Not sure about the capacitance if you don't connect the shield but that kind of defeats it's purpose, no?
Just for testing, to see if I can hear any difference.Structo wrote:Not sure about the capacitance if you don't connect the shield but that kind of defeats it's purpose, no?
