dave g wrote:It's absolutely possible. Just drive the 2-stage OD section with the EF86 preamp. You will have to use an OD input trimmer or control to pad the signal enough, but it should work fine.
What type of trimmer would you suggest?
What would be a good trimmer value to start experimenting with?
Rob
Music is an expression of the inexpressable ~ Vernon Reid, Musician.
