I just completed a this new JTM45 clone. It is not a kit, I bought my parts all around (end up expensive, about $1,100.00) but I'm proud of the results, good tone
I'm planning for a 2 X12 cab with greenback Celestion.
Audio circuit = Allen Bradley NOS carbon comp resistors
Power circuit = Takman - REX 1 Watt Carbon film (2 %) tolerance from Parts Connexion
Capacitors = Mullard/Philips NOS
Capacitors Bias circuit = Sprague Premium
Choke = Mercury Magnetic USA
Transformers = Magnetic components USA
Sozo 0.047uF 400V capacitor and 100K 2 Watts kiwame resistor on Standby Switch (very silent switching)
UK Cliff input and output jack
CTS potentiometers
Larry goounding schem
Hand made Paxolin dark brown circuit board, turreted
Metro-Amp aluminium chassis (polish)
Weber 25K bias Potentiometer
Ceriatone plexi front panel - Hand made rear plexi panel
v1 = Mullard Blackburn factory UK 12AX7 NOS
v2 & v3 = Mullard 12AX7 RI
v4 & v5 = Valve Art KT66
v6 = GZ34 Blackburn factory UK Mullard NOS (label G.E.B.)
[img
[img
[img
[img
I had a chance yesterday to try it with a 4 X 12 Marshall close cabinet with greenback and in a Avatar 2 X 12 also with Celestion speakers, awesome vintage tone in both cab.
I'm not a amp technician or amp guru, just a passionate hobbyist and to my big surprise the amp run without any issues right from the first start-up.
The only draw back I can see is the amp need to be crank high (over 5-6 on the volume) to deliver the nice Marshall crunch we expect. Bellow five, it's very clean (a la Fender).
Cheers, Jean
