output transformers interleaving...
swt
Post by swt »
does anybody know something about known ot interleaving? Twins...marshalls, or tweed?.
BobW
Re: output transformers interleaving...
Post by BobW »
Hammond and other manufacturers use interleaving as a common process to increasing coupling and efficiency. It also reduces leakage inductance.
Here more info:
http://focus.ti.com/docs/training/catal ... =SEM401014
Smitty
Post by Smitty »
Interleaving helps with the high frequency response of the output transformer. Twins have a 4/3 interleave which means there are four layers of primary with three layers of secondary in between. That's about as much as you'll ever need given that the high frequency content of guitar falls off at about 6kHz.
swt
Post by swt »
thanks guys....where can i get ideas abou the known ones...i mean...i have seen parallel secondaries, parallel then series, etc so as to complete the layers...and each on is different. there's so much mistery on ots...
