Midboost Footswitchable?
Is there anybody who tried to make the Midboost footswichable?
I own a Ceriatone Overtone HRM 100 an would like this function but I don't know how to realize.
Re: Midboost Footswitchable?
All you need to do is change the switch to a relay. It's a great feature.jazzcat wrote:Is there anybody who tried to make the Midboost footswichable?
I don't lose the function of the Midboost switch on the front this way?
(Sorry - but I try to learn)
Thank you!
Thank you!
Hi ,yes with a relay.
In all my amps I removed the front boost switch and it's only in footswitch pedal .
but you can leave both.
Sergio
Sergio
Not really. You can leave the switch to activate the relay, but once you turn it on the footswitch is inactive.jazzcat wrote:I don't lose the function of the Midboost switch on the front this way?
Thank you!
				toneslinger
foot switch midboost
Here is mine  this one came with my Texas Range ~ Master.
Shad Damrons approach to what you just asked about.
Thank you altogether,
its really nice to be part of this Dumblesound-Family, as a newby and that I get help. If the questions they are stupid (for you) or not.
Thank you altogether again !
				gilgalad101
The bluesmaster schematic has a footswitchable mid boost.
https://tubeamparchive.com/files/bm_dcl ... 12_171.pdf
Yes
Hi, I have that option on the foot-switch with the toggle on the back. I have played with the values for the mid-boost and currently I have  .002uf on the board and 470pf on the relay which when kicked in is 380uf.
[IMG 650]http://i260.photobucket.com/albums/ii9/ ... aster6.jpg[/img]
[IMG 724]http://i260.photobucket.com/albums/ii9/ ... cture1.png[/img]
Thank you!
It's great and will help me much.
I think that the midboost makes the Amp really flexible.
Clean and in overdrive, therefore, why not on a footswitch.
jeron
jeron
I don't have mid-boost on my tweaked D'Lite.
Do you use it? How does it sound?
Difference to the PAB?
This is a simulation of the skyliner stack with the various boosts.
[img:999:632]http://img.photobucket.com/albums/v21/m ... legend.jpg[/img]
Hope it helps.
Regards,
Markus
Hope it helps.
Regards,
Markus
Markus, did you simulate tonestack alone?
I can't get that high end rolloff considering tonestack only, see my simulation.
Is that from a Spice run?
Mark, what do the numbers on top of the graph signify?
