Trafo for dumbleator
sergio
Post by sergio »
Hi all , Where can I find a trafo to use for a D-lator in rack unit?
JD0x0
Re: Trafo for dumbleator
Post by JD0x0 »
someone mentioned using a weber reverb transformer. Someone else will chime in as i'm not certain on the exact required specs for a d-lator
Check out my thread. We discuss all that.
https://tubeamparchive.com/viewtopic.php?t=10162
sergio
Post by sergio »
Thanks Tom , it's was very helpful , my problem is always the voltage on primary , I'm in Europe 220/230V
I will do a search!!!
a good year for you and you all
llemtt
Post by llemtt »
Hi Sergio
if you want to use them inside a 1U rack may I suggest Hammonds
229B12 filaments
229B230 plates
cheers
teo
hbamp
Post by hbamp »
I have this one for you. They are custom made for me.
Prim: 115-0-115-0 Bridge for 230V
Sec: 135V@60mA; 12V@300mA; 6,3V@1,5A
H= 52 mm W= 65 mm D=40mm
Dutch hand build amps
nickm57
Post by nickm57 »
If you don't mine me asking, what is their cost
Nick
erwin_ve
Post by erwin_ve »
You can also use 1n242 from Amplimo: http://www.amplimo.nl/index.php?page=sh ... 34&lang=en
I build 4 units with it. They all work fine.
sergio
Post by sergio »
Thanks to all guys!!
always a lot of help here, this is an excellent forum. :wink:
now there is a lot of choice...
Thanks all :wink:
jaysg
"trafo"
Post by jaysg »
Sergio, what is the full Italian word for 'transformer'?
paulster
Post by paulster »
hbamp wrote:I have this one for you. They are custom made for me.
Presumably EI laminations rather than toroidal since it's rectangular, or is it encapsulated?
Is the secondary 135-0-135?
sergio
Post by sergio »
For jaysg
Transformer = Trasformatore
Bye
hbamp
Post by hbamp »
Nick
PM me.
hbamp
Post by hbamp »
See drawing please. H = 52mm
BobW
Post by BobW »
sergio wrote:For jaysg
Bye
OK this may explain why transformer or the commonly accepted English abbreviation XFRM has changed to TRAFO (German translation).
With all respect to Nikola Tesla, I'll continue to use XFMR. for the same reason why I use eight instead of ocho.
http://acronyms.thefreedictionary.com/XFMR
http://acronyms.thefreedictionary.com/TRAFO
