Switched LNFB loop on V1b...
Bob Simpson
Post by Bob Simpson »
On/Off/On switch / 22m resistor / .05mfd OD Cap / 22m resistor...
Pretty much stock...
The question is... how stout does the switch need to be?
Will a Mountain mini be ok, or should I use a full size NKK?
Brands of switch are not of import to me, but if the smaller switch is adequate, I'd rather use that... Real estate is at a premium between V1 and V2 as it is...
TIA
Bob Simpson
dogears
Re: Switched LNFB loop on V1b...
Post by dogears »
Mini is fine. Put the switch on the side that has no dc.
Bob Simpson wrote:On/Off/On switch / 22m resistor / .05 OD Cap / 22m resistor...
TIA
Bob Simpson
