Here is the main schematic for the Rev-A-Loop.  I did not draw up the power supply as it will depend on the transformer used.   A transformer around 600v CT should be adequate to get the required voltages.     The one I used was salvaged from a 1960's  vintage Viking reel to reel recoder preamp.
Gary
						Reverb - A -Loop Schematic
- glasman
About 5 miles south of I-94
www.glaswerks.com
www.glaswerks.com
Stupid question maybe...but
I see that the bottom part is the reverb circuit.. But what is the upper part? Is it the dumleator, or is the whole thing for the reverb?
I wondered since there is an input, then a send and return, and then an output, in addition the the reverb part..
Tommy
Tommy
- glasman
Re: Stupid question maybe...but
It is a d-lator with integrated parallel processed reverb.Tdale wrote:I see that the bottom part is the reverb circuit.. But what is the upper part? Is it the dumleator, or is the whole thing for the reverb?
Tommy
Gary
www.glaswerks.com
www.glaswerks.com
Re: Reverb - A -Loop Schematic
Ok.. nice.
Is placing the reverb circuit with the dumbleator a better way of doing it than the normal placement, or is it just to make it convenient with the two circuits in the same chassis?
I have a schematic I made (with some assistance) that has a built in dumbleator between the preamp/OD and power section. I'd like to add a reverb, but I'm not sure where to place it. I planned to do it like Ben, using 3 tubes....
Tommy
Tommy
- glasman
Not sure if it is better. It was just something I felft compelled to doTdale wrote:Ok.. nice.
Tommy
www.glaswerks.com
www.glaswerks.com
