question about express layout
mc2
Post by mc2 »
Can anyone explain what part values are between pins 1 and 3 in the attached illustration and what their function is? Thanks in advance...
[/img]
nickt
Re: question about express layout
Post by nickt »
They're 3x IN4007 diodes in series.
I think they're there to prevent the plate going negative WRT cathode. They're basically a safety feature and have no effect on tone.
benoit
Post by benoit »
I can tell you for sure that they're diodes. They're unique as far as I've seen to the Kelly 90 schematic. They are connected between the cathode and plate of the 6l6s.
According to Allynmey they protect your OT from transients and in case of tube failure. I think the idea is the breakdown voltage is such that if there were a really bad voltage spike the diodes would short the circuit.
This thread has a little info:
"https://tubeamparchive.com/viewtopic.ph ... ly++diodes
I think it would also protect the OT in the event the amp got started up without a load on the output.
Someone who actually understands how this works, please correct/clarify my info.
Allynmey
Site Admin
Post by Allynmey »
Ken used them in a lot of his amps. They are documented in "The Trainwreck pages" in gerald webers books. They are protection for the OT if a tube shorts and for transient spikes of current.
Allynmey
benoit
Post by benoit »
Are those the same TWreck pages in the files section?
paulster
Post by paulster »
The diodes are to protect both the tubes and the transformer against flyback transients.
A 1N4007 has a reverse breakdown voltage of something like 1000V, after which it will conduct in both directions. In the Express example, with three connected in series between the plate and ground, they won't conduct until there is a voltage of above 3000V at the plate, and this will then be dumped to ground rather than into the output tube.
It also prevents the inductive nature of the transformer from attempting to raise the voltage higher in order to maintain the magnetic flux (as inductors do), which would ultimately result in arcing across the windings and permanent damage to the transformer.
rfgordon
Post by rfgordon »
Do the diodes provide the same protection in a cathode bias amp?
Rich Gordon
paulster
Post by paulster »
They'll work just the same in a cathode-biased amp.
I use them routinely as a safety measure in all new builds as half a dozen 1N4007s cost significantly less than an OT or a pair of NOS tubes. 8)
gearhead
Post by gearhead »
benoit wrote:Are those the same TWreck pages in the files section?
No, it's in the builders interview section at the back of Webers book, "Tube Guitar Amplifier Essentials".
It is still in print, so go get a copy! Or do it on the cheap; Borders sometimes has them in stock. Buy a cup of coffee and read ;)
That interview alone is worth the price of the book, plus it's a pretty good book.
