Odyssey Power Amp...
thyx
Post by thyx »
...does anybody have a schematic or layout for one of these little beasts?
BTW, nice to see the board humming again. 8)
thyx
Re: Odyssey Power Amp...
Post by thyx »
Specifically, I'm looking to find out how the 12BH7 is set up. Is it similar to the way the cathode driver in the SSS is?
Not much out there on this amp. Not sure if they are real Dumbles either.
Auralalchemy
Post by Auralalchemy »
thyx wrote:...does anybody have a schematic or layout for one of these little beasts?
I don't know but I will sell you the one in the bottom pic for $4500. It's sitting right here at the end of my couch.
Rob Curtis
selloutrr
Post by selloutrr »
My Daughter Build Stone Henge
boldaslove6789
Post by boldaslove6789 »
Can anybody glean enough info to make some sort of layout/shemo out of the Odyssey posted above? This would be very cool to have to go with any D-style amp.
txbluesboy
Post by txbluesboy »
Looks to me like it's driving the power tubes off the plate, not the cathode, of the driver tube.
thyx
Post by thyx »
txbluesboy wrote:Looks to me like it's driving the power tubes off the plate, not the cathode, of the driver tube.
Yes it is...and I suspect it (the 12BH7) is being driven by a 12AU7 PI. After pooring over the photos, it's basically a Twin Reverb output but with a PI/driver setup (like a Dumbleland) and a Master Volume at the PI input.
glasman
Post by glasman »
To me it looks like
Tube 1 - Gain Stage and cathode follower.
Tube 2 - PI
The rest PA section.
Not much to replicate.
start with a fender PI and PA and roll your own Gain/CF
Gary
About 5 miles south of I-94
www.glaswerks.com
Max
Post by Max »
Hi,
AFAIR:
V1 = 12 AU7 = Phase Inverter
V2 = 12BH7 = Driver
V3 - V6 = 6L6
Max
boldaslove6789
Thanks guys
glasman
Post by glasman »
Max wrote:Hi,
AFAIR:
V2 = 12BH7 = Driver
V3 - V6 = 6L6
Max
Common cathode driver stage??
www.glaswerks.com
groovtubin
oddysey ppre-amp scizo rough drawing
Post by groovtubin »
should be close!
Max
Post by Max »
glasman wrote:
Max wrote:Hi,
AFAIR:
V2 = 12BH7 = Driver
V3 - V6 = 6L6
Max
Hi Gary,
AFAIR Alexander Dumble used a PI > driver structure in a lot of his amps. Here's another example from Rob Livesey's page: http://personalpages.manchester.ac.uk/s ... 086872.jpg
Max
txbluesboy
Re: oddysey ppre-amp scizo rough drawing
groovtubin wrote:should be close!
That looks right to me except you omitted the (.1?) coupling caps between the 12K plate resistors and bias mix resistors.
