How to handle music man PT, OT in ods.
Frankie
Post by Frankie »
I have a music man 65 amp that I can use as donor in my next build.
How can I handle the voltages from the trannies. I know they are very high.
I`m planning to build a non hrm ods.
Re: How to handle music man PT, OT in ods.
I think Dumble used those as well.
A EL34 is said to have a VaMax of 800v and max screen volt at 500v.
Where as a 6L6 is limited to 360v or so.
Plus a few Kinkless Pentodes can handle higher voltages as well.
KT77 - 800v
KT88 - 800v
dogears
Post by dogears »
My Bludo runs 700+ volts on the plates of the 6L6 tubes. Never blown one. Knock on wood..... Screens run 1/2 the plates. I have them biased at 25ma
Here is a clip from yesterday. The low end wooliness is awesome!! Music Man iron and 6L6 tubes are magic.
http://scottlernermusic.com/Bludo/MrMagicBludoOD2.mp3
Structo wrote:I think Dumble used those as well.
KT77 - 800v
KT88 - 800v
talbany
Post by talbany »
You can run either Tong Sol Reissue 6L's , Solvtek 5881's. JJ 6L's.. All can handle the 700v..(350 screens) Music man Iron Kills!!! :twisted:
Bob-I
Post by Bob-I »
I've looked over the MM schematics and I'm lost. My little pea sized brain just doesnt follow the power supply or out section.
There appears to be voltages from 2 places on the PT, one side goes to a voltage doubler, but on the other line I don't see any rectifier.
Im also looking at the output and I don't see any signal doig into the control grid :roll: . It appears to se sending the input into the cathode and only bias voltage going to the grids.
I'm so confused.
ToneMerc
Post by ToneMerc »
Frankie
Post by Frankie »
My music man 65 amp measured 780 volt, and 390 volt(screens).
Will that be to much for the D build ods?
I will use EL34 tubes.
