Starting Liverpool build
Guys
Here's some early pics of a Twin Tube EL84 Liverpool build I'm working on. It's got Edcor Xformers, CDE film caps and Takman REY 1 watt metal film resistors.
I won't be building a clone Liverpool but my version of the amp. Like I did with my Rocket and Rockster...
Re: Starting Liverpool build
I love the look of those blue bells.
And being a frugal New Englander their prices are great. $140 for both the PT and OT and shipping. Of course there is a small wait while they build them but I just source my other parts then.
And have been happy with the sounds too. I think even Mark Fowler likes these...and he builds a ton of amps, like yourself.
Yes I do like the blue bells.
Would you mind explaining the tone stack - I only see 2/3 of the tone stack caps. Do you move the other .022uF onto the pot?
kwijabo
Good eye, not a real big fan of the "middle" tone control so went only treble and bass with a cut control ala the Rocket. Again not a clone but based on the Liverpool somewhat...
Since the last post I got the transformers in and wired up some of the chassis connections. Tube sockets and switch and indicator light.
And I populated the two boards. The Takman resistors have bigger wire than usual so fitting two into a turret was hard. I had to drill out some of them to make it work. Not the work of art you guys post but it should work fine here in the basement.
- Turbojunkie
Looking good!
I'm digging the chassis service rack you have, is that something you built or purchased?
Very nice Joe, looks sharp.
Looking good, I used Edcor transformers in a few builds and they sound good.
Like the variety you can order from them and they seem well made.
Turbo
Yeah I made it, it's made from 80 20 1 inch stock. All pieces right from their catalog.
Dave,
Thanks sir!
Jeff,
Yeah I like the Edcor stuff. Built a Rocket, Rockster, and now the Liverpool with their transformers. And lots of choices too.
Dave,
Thanks sir!
Jeff,
That is a good way to go with filter caps.
- RJ Guitars
Nice looking build Joe. I really like the Edcor transformers in the 15 watt format. Great photos, thanks for sharing the details.
http://www.rjguitars.net
Sure is, I got it from your Rocket build. And you can move the two sections around to fit any chassis.
Thanks.
Rj,
Thanks, I find the Edcors work great and you have some great ones for more powerful builds too.
Thanks.
Rj,
