Asteroid Layout
Asteroid Layout
PM me
									Great things happen in a vacuum
						Re: Asteroid Layout
That layout looks great. Thanks Barry,   Chad
						Re: Asteroid Layout
Oh, my, someone is feeding my sickness once again.....
									Rich Gordon
Re: Asteroid Layout
Great Layout Bnwitt - What transformers are used & what did you use as the basis for this layout?  I havent heard any clips of the asteroide, how does it differ from the express sound wise?
JOE
									JOE
Resistors not Transistors !
						Re: Asteroid Layout
Joe,joe6v6 wrote:Great Layout Bnwitt - What transformers are used & what did you use as the basis for this layout? I havent heard any clips of the asteroide, how does it differ from the express sound wise?
JOE
take a guess
				gregarious
Asteroid Layout
Very nice work Barry. Now if only a beautiful chassis was available to house it, and some snazzy trannies to juice it up!
Allyn?
 Allyn?
				Fischerman
Re: Asteroid Layout
...how does it differ from the express sound wise?
Like a chewy Komet?...take a guess
Re: Asteroid Layout
You are correct oh wise one.Fischerman wrote:...how does it differ from the express sound wise?Like a chewy Komet?...take a guess
						Re: Asteroid Layout
bnwitt wrote:You are correct oh wise one.Fischerman wrote:...how does it differ from the express sound wise?Like a chewy Komet?...take a guess
Re: Asteroid Layout
OK - OK , I guess I must have been in outerspace, I mean layouts like this just dont fall from the sky. But still , any info on the trannies? recomended secondary voltage & MA ?Joe,
take a guess
JOE
						Re: Asteroid Layout
Joe,joe6v6 wrote:OK - OK , I guess I must have been in outerspace, I mean layouts like this just dont fall from the sky. But still , any info on the trannies? recomended secondary voltage & MA ?Joe,
take a guess
JOE
you is so funny
   I'll pm ya.
  I'll pm ya.Great things happen in a vacuum
						New layout with filter cap notes
I added some notes on the 4 main filter caps of which two are on top of the board and the other two are directly under the board in series with the partner cap above.  This of course gives you 40uf with 900 volts for each set of the two 80uf 450v caps
						Re: Asteroid Layout
Reversed V1 cathodes corrected on layout.  Current version is #8
						Re: Asteroid Layout
Isn't the negative voltage to the bias pot taken from the negative side of the other 8uf cap?
