Electroswitch Wiring Diagram
UltraHookedOnPhonix
Post by UltraHookedOnPhonix »
I'm pretty sure this is how to wire the Electroswitch DG40303N
[IMG:800:799]http://i205.photobucket.com/albums/bb17 ... Wiring.jpg[/img]
Anyone see anything weird?
Re: Electroswitch Wiring Diagram
Whoa! :shock:
Is this a joke?
If not, I just use the switch from Hoffman and connect four wires to it and call it a day.....
UltraHookedOnPhonix
Actually, no.
This is the exact switch used in many recent Dumble amps, like this one:
[IMG:800:535]http://i205.photobucket.com/albums/bb17 ... lector.jpg[/img]
If a connection goes bad on the switch you are talking about, your output transformer is left hanging without a load (ouch!!!). Not so with the wiring accomplished with this switch.
Guitarman18
Post by Guitarman18 »
Thanks for doing this UltraHookedOnPhonix. Even though I wired mine up a while back, (I haven't got trannies in, so have not test fired yet) it's nice to get confirmation that my grey cells are working.
This is a 3-pole switch, so wired this way it is triple-redundant, and if all three contacts are functioning the current rating (per the data sheet) is 1.5A for each contact x 3 = 4.5A @ 28VDC. Even this is cutting it close though, since 100W into 4 Ohms is 5A (at 20V).
This seems to be a common theme from a fail-safe point of view, as you can see in the #124 pictures the PAB and OD DPDT slide switches are wired as two SPDT's in parallel.
MPM
Noel Grassy
Post by Noel Grassy »
Yeah, but thankfully the Hoffman (NKK) switch has massive blades for each section. They'll glow for awhile before buckling and taking out your OT iron.
I like the triple redundancy factor never the less! :wink:
tubedogsmith
Post by tubedogsmith »
where do you get these things?
ic-racer
Post by ic-racer »
Excellent, thanks for posting I have been wondering about it for my HRM layout. Maybe there is some way I can show this on the HRM schematic.
Without the switch in hand, I was unable to figure that switch out based on the switches datasheet.
Funkalicousgroove
Post by Funkalicousgroove »
just wire it in paralell
UltraHookedOnPhonix
-Tubedogsmith-
Seems the majority of these suppliers are running low on stock:
www.mouser.com Part#: 690-D4G0303N
www.alliedelec.com Part#: 747-7080
www.digikey.com Part#: 451-1099-ND
www.newark.com Part#: 06M4664
www.onlinecomponents.com Part#: D4G0303N
ic-racer wrote:Excellent, thanks for posting I have been wondering about it for my HRM layout. Maybe there is some way I can show this on the HRM schematic.
Assuming the 4-Ohm setting is CCW, something like this?
MPM
tubedogsmith
UltraHookedOnPhonix wrote:-Tubedogsmith-
thanks!
glasman
Post by glasman »
I have been using the NKK in several amps for over ten years, no failures. Better rating also, 6A @ 125V ac.
Gary
About 5 miles south of I-94
www.glaswerks.com
guitarsnguns04
Post by guitarsnguns04 »
for guys whos use a switch with just four terminals is there somehing we could put into the circuit to protect our trannys in the event of a switch going bad?
UltraHookedOnPhonix
Quick off-shoot:
Dumble #183 or #184 (made in 87') seems to have been the first ODS to feature the impedance selector.
Dumble #182 and #185 (strangely enough) doesn't feature the switch.
