Dumble Overdrive Special 80's Chassis Dimensions?
selloutrr
Post by selloutrr »
Sorry i'm sure this has been posted several times but it's escaping me. What are the correct chassis dimensions for a Dumble Overdrive Special 60's and 80's model?
Thank you.
My Daughter Build Stone Henge
dano-rator
Re: Dumble Overdrive Special 80's Chassis Dimensions?
Post by dano-rator »
Hello,
"martin manning" has done a very detailed layout of ODS #124 (circa 1984) chassis in the dumble files section, and I believe he was striving for historical accuracy. Those dimensions are 19.5" wide, 8" deep and 2.38" high - if this helps.
Ps. best forum on the internet barre none! Many thanks to admin et. al.
Dan
selloutrr
Post by selloutrr »
Thank you!
quick question are his dimensions correct or is this?
aluminum 2mm thick
measures
19 1/4" wide
8 5/8" deep
2 5/16" tall
Those look like the dimensions of the Natchanis chassis. I used #124 photos and known part dimensions to get mine. Anybody get measurements from a physical unit? I'd be glad to update the drawing.
MPM
