New Champ AA764 PTP build
Finally got around to building my Champ AA764 PTP for fun and giggles.
High input gets the dirt for some low volume fun.
Wayne
Re: New Champ AA764 PTP build
Post by Wayne »
Sweet!
Colossal
Post by Colossal »
Very nice Mark!! How does she sound? I like the caged chassis.
Dave, thanks
It sounds like a Champ :)
Quiet, nice clean low input but high input snorts at that low volume sometimes necessary to keep peace in the home front :roll: . It looks good next to the recent Bassman 5b6 I did.
angelodp
Sweet
Post by angelodp »
Gotta love the Champ tone. What no reverb ??
Maybe a vibrochamp but no reverb. :)
I had to change out that pilot light you see in these pictures I got them from apexJr. No matter how I wired it no good. I tried all of the lights with battery as well and I cannot get it to light up. Has a terminal on each side and center terminal (?ground). Dam near burnt up the amp trying to wire that light.
Anyone got suggestions?
Sonny ReVerb
Post by Sonny ReVerb »
Bad bulb?
"The blues is the roots, the rest is the fruits." - Willie Dixon
No I checked every assembly all the same with good filament in the bulbs themselves. I do have a pack of bulbs and can try replacing each one (4) and see if that makes a difference. Why is there three connections?
Sonny ReVerb
Hmm, I think that's like the one I got from Apex that I used on one of my amps. Is there continuity between the two tabs on the sides? The tab at the end should go to the base of the lamp. I'd take the bulb out and use your meter to see where there's continuity between the tabs and the internal socket. Sometimes the base of the lamp doesn't make good contact with the socket, as well.
Maybe it's a bi-color like Crate uses - amber for Channel A and red for Channel B. ;)
see page 4: http://www.crateamps.com/pdf/manuals/VC120H.pdf
Yeah, I checked, it's exactly like the one in my cakepan amp. I connected to the end tab and one of the side tabs.
[img:256:393]http://img44.imageshack.us/img44/1676/cakepanjl.jpg[/img]
I'll try fart around with it some more.
# 47- 6 Volt Panel Light with Red Lenes cap with hardware $1.50ea
