I just fired up my newly built 2550X Silver Jubilee based on the SDM files from Valvestorm with only a few modifications as usual, and shoehorned into an 18-watt chassis. Data below. The amp is fully functional at the slightest opening of the master volume. When not playing, it's whisper quiet. No red-plating. The preamp controls all function, the relays and switches all function. When I turn up the master, it starts to sound like a bitcrusher when playing notes. I reversed the OT primary leads and got the same thing except it sounded like a nuclear fuzz pedal at all settings. Just initially thinking this through with my limited knowledge, I could be getting oscillation with the presonance part of the circuit as others have reported, or the FX loop delete point. Not sure. Here's the data and photos:
2550X SILVER JUBILEE CLONE A LA SDM
PT: HEYBOER 50W APD-8023H
OT: HEYBOER 50W APD-8025H
CHOKE: HAMMOND 159R 200mA 150R 500V
Electro Harmonix EL34, 12AX7s
F&T 50uF can capacitors
Synergy Mustard/Sozo caps
Sprague Atom E-lytics
Mods:
1) Schaffner AC Module
2) Standby switch delete--CL80 Thermistor on AC Hot post-switch
3) 500 mA fuses on HT and 6.3V heater CTs
4) Individual Lead and Clean Gain controls
5) Clean and Lead 3-way Bright switches
6) Hoffman 5VDC relay boards and power supply
7) Custom board
9) Original FX Loop delete (Metro ZL Loop to be installed later)
10) Default Clean channel instead of Lead.
11) Direct Out delete
12) Half-Power switch delete
VOLTAGES:
WALL AC = 120V
HTS = 333 VAC
B+ = 427 VDC
HEATERS = 6.3 VAC
V1:
P1 = 236
P3 = 1.8
P6 = 209
P8 = 1.4
V2:
P1 = 210
P3 = 1.6
P6 = 107
P8 = 0.47
V3:
P1 = 239 [corrected]
P2 = 24.9
P3 = 40
P6 = 233
P7 = 26.2
P8 = 40
V4:
P3 = 425
P4 = 421
P5 = -39.5
P8 = 34 mV
V5:
P3 = 426
P4 = 420
P5 = -39.5
P8 = 35 mV
The Presonance circuit is on a small secondary board bolted underneath the bass control on the chassis with a G10 spacer underneath to prevent grounds. It was really hard to make room for everything on this build. I'm sure I could have done it better, but this is my first Jube, so I appreciate your advice. I thought I'd ask before I replace the Presonance with a 5K/0.1uF presence control like the SDM "original". Thanks as always!
[nfb tap corrected from 8R to 4R]
[PI PLATE LOAD RESISTORS ADDED!] Original SDM 2550X SCH: Original SDM Layout:
https://el34world.com/Forum/index.php?a ... 0023;image
