V1a plate will probably be 330K or 390K. Not a huge difference either way (I've tried both in the past).
Clipping/clamping options: I'm still up in the air. I might try 18v and 9.1v or 18v and something like 11-12v.
Will use a switch for the resistor on Gain 1 to ground. Some call this a "focus" control. I rarely use it. Have always used 82K here but maybe something lower, like 68K might be a nice option.
I play a very bright guitar with no tone knob (Mayones Duvell), and I've found I like the 0.001uF "dull" cap on the grid of the second stage to kill some highs. But some say it's better on the other side of the grid resistor?
Another option is to bypass the plate resistor with a small cap, like 330pF or so. But I have a question about this:
Should I bypass the 330K plate resistor, or should I split it up into two resistors like a 100K and a 220K, and then bypass just one of them? And if I do that, does the order matter?
I assume people who mod existing stock Marshalls add a second 220K resistor and leave the original 100K in the circuit either because it's easier or to retain the original parts of a vintage amp? But is there a sonic difference?
B+ --> 100K (bypassed) --> 220K --> socket
B+ --> 100K --> 220K (bypassed) --> socket
B+ --> 220K (bypassed) --> 100K --> socket
B+ --> 220K --> 220K (bypassed --> socket
B+ --> 330K (bypassed) --> socket
Larger version: https://orig00.deviantart.net/7970/f/20 ... ckc5mf.jpg
