Which circuit do you guys prefer?
When you guys build JCM800 50w clones which presence pot circuit do you like best 5KL or 25KL?
						Re: Which circuit do you guys prefer?
5k
									www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
Seconded. 5k.
Thanks guys I will install the 5kL.
						- Reeltarded
yeah yeah my amps are basically sort of 800s with plexi Pres.. the 25k circuit is weak and meh
						- pompeiisneaks
- Site Admin
I swear I read and/or heard that the 25k is poorly designed because the way the circuit works, it can only use the first 4 or 5 k anyway and the rest is wasted, no?Reeltarded wrote: ↑Wed Aug 15, 2018 1:40 pm yeah yeah my amps are basically sort of 800s with plexi Pres.. the 25k circuit is weak and meh
~Phil
tUber Nerd!
						- Reeltarded
You turn the knob and if you don't hear DC scratch, you won't hear any real change at all. The early one does too much and too little. That's perfect.
The 25k is a waste of a control, a hole, the components..
				RockinRocket
Pompi and Reel you've lost me.
Alberto did a amazing job analyzing the frequency sweep on my questions of the differences between the two.
They are more or less the same in frequency. No DC scratch on the 25k but the actual sweep in the 25k does not react Linearly like the 5k pot setup.
				FourT6and2
What about the 5K pot plus the 4K7 resistor like in the 25K pot version? I have an amp here that came with that and it surprised me to see that.
				RockinRocket
It works but you have half the range as a 25k pot 4k7 circuit.FourT6and2 wrote: ↑Fri Aug 17, 2018 1:19 am What about the 5K pot plus the 4K7 resistor like in the 25K pot version? I have an amp here that came with that and it surprised me to see that.
5k/no reistor has the largest frequance range of the circuits.
What ampin question?
I prefer the 5k too. I just don't like the sweep of the 25kB (with || 4k7 R) pot.
				FourT6and2
Interesting, thanks. The 4K7 resistor is there to block DC, right? But it also changes the sweep/frequency range of the pot?RockinRocket wrote: ↑Fri Aug 17, 2018 3:19 amIt works but you have half the range as a 25k pot 4k7 circuit.FourT6and2 wrote: ↑Fri Aug 17, 2018 1:19 am What about the 5K pot plus the 4K7 resistor like in the 25K pot version? I have an amp here that came with that and it surprised me to see that.
				RockinRocket
Correct. The frequency range is more or less the same but the sweep is very bunched between 1-5 and then very spread out. So its not linearly even though the pot is linearly.
I believe the difference is because the cap on the pot is wired differently. Joins from the wiper to a end.
No, resistors do not block DC. The 4K7 provides a dc current path for the PI cathodes.FourT6and2 wrote:... The 4K7 resistor is there to block DC, right?
				FourT6and2
