Thoughts on Marshall bright caps?
Marshall Amp Discussion
randalp3000
Post by randalp3000 »
Just finished a low watt JMP type amp with the .005 bright cap on the volume control. This seams a bit high to me. https://tubeamparchive.com/viewtopic.ph ... 745#333745
Do any yous guys have favorite values for the bright channel?
thanks
randalp
JoeCon
Re: Thoughts on Marshall bright caps?
Post by JoeCon »
Randal
One of the resident plexi/Page master builders here sent me this...
“For the Page tones one of the tricks is having that 5000pF bright cap over the Bright channel volume. “
So if it's the Page tone you're going for, you got it!
Here's were you need a capacitor substitution box to try out different caps.
I'm inclined to say no more then 500pf.
I've seen it from 100pf, 500pf, .002, and .005?
norburybrook
Post by norburybrook »
In my JTM 45, 500 was too bright for me too, I ended up with 100 if I remember correctly.
Marcus
randalp3000
thanks for the reply's guys.
the .005 bypasses soo much it's hard to control and mix the 2 volumes. I like how it sounds but it's very hard to dial it in. I may monkey around with it some more when I get home.
BTW this amp rips ass :evil:
The 5kp is the awesomes on a straight circuit though.
The 500 only makes it sizzle more. The 5k makes it go! As you can imagine it's nearly full volume before 50% rotation though. :)
I think I have mostly 4k7p and 2k2p on my amps. Much smaller on the cascaded ones gain controls. 100/250/500..
Roe
Post by Roe »
The way to go, IMHO, is to use a push-pull pot for switchable 100pf/5nf. This works well on all the plexi circuits and all volume settings
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
Roe wrote:The way to go, IMHO, is to use a push-pull pot for switchable 100pf/5nf. This works well on all the plexi circuits and all volume settings
I was just about to suggest this Roe and would be the best solution.
randalp3000
that's a great idea. I was hoping to avoid any switches but I might have to throw one in.
so far keeping it stock at .005 for this weekend.
randalp3000 wrote:that's a great idea. I was hoping to avoid any switches but I might have to throw one in.
Use a 1MA push pull CTS pot for your switching.
That is worth doing.
jelle
Post by jelle »
.005 for kick ass marshall rippin' tones.
beasleybodyshop
Post by beasleybodyshop »
i used the push pull pot in my last build. Worth it! gives you options without drilling holes.
i dont like the torque of the pp pots though, but worth the tradeoff!
