2555 Silver Jubilee treble issue
Marshall Amp Discussion
OSMOSE
Post by OSMOSE »
Hello
I have a 2555 Silver Jubilee in pristine clean condition that I've owned since 2003. Filter caps have been changed for JJs by a reliable tech a while ago, every buttons and pots work smoothly, it's been well taken care of. I've played it extensively for 5 years with a Dr. Z Airbrake attenuator, then it's been sleeping in it's flycase because I was unable to play loud enough anymore. I recently got into a loud band again and just started using it again, never being able to feel satisfied by what I was hearing anymore... so trebly, bright and harsh. I first got rid of the attenuator because I was just sick of it sucking the sound and I can play very loud so let it be... I play 100w mode clean channel, input gain and master volume are about 8 each. I set my presence at 2.5 bass on 10 mids around 5 and treble... 0 and I would go -10 if I could no kidding...
The amp has always been bright but it's become unusable really, I can't remember it being this unplayable, I wonder how could I ever have plugged a wah into it, I can't get anything out of it anymore, fuzz and distorsion pedals suck badly, it's just awful. The bass is tight as ever, mids are nice, but what's up with the treble I have no idea. I've never been higher than 2-3 and I know that's the setting John Frusciante uses so I've never been scared of playing that low, but I'm not getting anywhere now. I still play the same cab as I used to, standard 1960A, and I tried others with the same issue.
Any idea where that might come from and how to get this problem fixed? I've pondered clipping the bright cap but geez... will that even be enough, and I play loud so will it make any difference anyways... when I hear that some set their treble on 6-7 I guess something's wrong with mine... :?
Thanks for your help.
Much love
OSMOSE
Re: 2555 Silver Jubilee treble issue
Post by Stevem »
As preamp tubes get weak they not only drop gain out but there current output drops off big time so your guitars signal has a hard time getting pushed thru the amps tone controls, and this can leave you with a lot of high end and little to no bottom as high frequency`s have much more natural energy to them so that what dominates!
OSMOSE
Post by OSMOSE »
Yeah definitely, thanks for your answer, but I just got a fresh set last week... :/
JerryFJA
Post by JerryFJA »
I'm going to guess you don't use the effects loop? Clean the effects loop jacks and see if that helps.
Jerry
OSMOSE
Post by OSMOSE »
Yeah good guess I don't use it. I'm gonna try it, also got advised to try putting a jumper cable on the loop.
Littlewyan
Post by Littlewyan »
Do the tone controls all work ok? Play the E string constantly with one hand whilst turning each knob from 0 to 10 with the other.
OSMOSE
Post by OSMOSE »
Cheers, I will try and report asap.
OSMOSE
Post by OSMOSE »
Hello guys
I cleaned the pots and jacks, changed the power tubes again, and it's back to awesome sounding. Thanks for your help.
vibratoking
Post by vibratoking »
OSMOSE wrote:Hello guys
Glad you got it running. Kinda too bad that you didn't take the time to discover the real culprit.
Electronic equipment is designed using facts and mathematics, not opinion and dogma.
