18watt superlite pix new build
I had a trainwrek chassis i drilled backwards so i used it for this 18watt superlite,  the power transformer is a hammond 261g6 which to my findings is just perfect for a superlite.  315 on plates 304 screens i also used a real 18watt output transformer from classictone and am stoked with this amp, I also used a mastervolume on the PI like a spitfire and it works perfectly i can dial-in a super chrunchy 18watt tone @ whisper levels can't wait to give it a good cranking when i get home from work.           mark
						Re: 18watt superlite pix new build
So you get it cranked up yet ?
Currently working on a plexi 6v6 in the reversed wreck layout
