"package deal" 82k / 100k plate loads and tail resistors to 470R/15k for the PI; PI null input cap to .047; output couplers to .022; output grid leak resistors from 470k to 220k, and reduced power tube cathode cap from 470uF to 47uF.
I removed the 200R in the screen supply so there are just the two 820R's at the screen pins. Brave, aren't I?
Put back the 1uF bypass on V1b (I was playing with that value for treble and it was down to 0.1...so back to the known starting point there).
Lifted the signal leads for both the "low" inputs just for now at their input jacks.
Elevated the heaters using 180K / 47K w/ 33uF 100v cap.
I went to take another look at /measure the values I had used on the pots. I think the treble issue was at least partly because I strapped a resistor across the treble pot outside lugs (I had a 500K and it calls for 250k which I gotta order some of).
And here's where the story gets a bit funny when using stuff "from the boneyard". The master vol pot, turns out is not a 1meg as I (could have sworn I know I DID...) measured before installing. Its a 0-250K center-0 pot (really odd) must have been a balance control or something but never seen that one before. I know that's what it is 'cause I measured it 5 times in disbelief. Replaced with a 1 meg.
Yet to do: Swap the bass pot for a 1 meg, and add the .68 cap to the V2a 820R since those are not "critical" ... yet. I have massive updates to do to my schemo now too and once this is done will edit the post to reflect the changes.
All proof that I should have asked FIRST, not rebuilt three times...ahem!
