JTM45 Build
- Littlewyan
Re: JTM45 Build
I think I'll keep it all standard. I was thinking of going all the way and making this an era correct amp with all of the correct parts, but the cost just shot up immediately and got a bit silly. So I think I'll keep the circuit original but use mostly new parts. May use older capacitors for things like the mixer bypass, tonestack and bright cap though.
- Littlewyan
Re: JTM45 Build
I've got my chassis and faceplates long with a few other bits from Michael at Modulus. The faceplates look amazing, I will post pics up once I've started building. However before I start building I need to decide what direction I'm going to take this amp in.
Basically I don't think KT66s will give me the sound I'm looking for. I watched quite a few videos of 66-67 Marshalls that used EL34s and thought they sounded fantastic. All of the Marshalls with KT66s that I listened to seem to have less crunch, less mids and the distortion that was there was a bit harsher perhaps? Definitely not as smooth as the EL34 Marshalls.
I've looked at various different Marshall amps from that era and I believe there were a few with EL34s that had white rear plexi panels.
What do you guys think?
- Littlewyan
Re: JTM45 Build
I ended up buying a transformer set from Classic Tone. Bought the JTM45 PT, 50W EL34 OT and 3H Choke. They arrived today.
First issue, can't install the PT as I don't have any Imperial American sized nuts. I need #8-32 Hex Nuts. Grandad has a box full of nuts and bolts so I'm going to go through that tomorrow night, if I have no luck there I'll have to order some online and wait a few days for them to arrive.
Second issue - Chassis has marks all over it from when I drilled additional holes. Scuff marks etc. Unfortunately I don't have a proper work bench so had very little space to work ;(. Anyway Michael at Modulus Amps said I should be able to polish it up again as its aluminum. Going to look into some stuff for that tomorrow.
Re: JTM45 Build
Find your nuts!
And get us some pictures
Hope you get all your stuff without to much of a headache.
- Littlewyan
Re: JTM45 Build
Polished chassis with a few bits installed.
Re: JTM45 Build
looking good...keep going...nice shine on the chassis
- statorvane
Re: JTM45 Build
Yup. That's gonna be a keeper alright.
- Littlewyan
Re: JTM45 Build
I've bought a Red Marshall 6V indicator lamp for the amp and the lamp has a little nib on it which pushes against the faceplate. Is there supposed to be a cut out for the nib? I vaguely remember the indicator on my 1987xl sticking out slightly on one side so maybe its just there to push against the faceplate.
- statorvane
Re: JTM45 Build
I've bought them from AES and Tube Depot. I do not remember a nib. Probably just some flash left over from the manufacturing process.
[img
768]http://i165.photobucket.com/albums/u76/ ... 35e3a5.jpg[/img]
[img
768]http://i165.photobucket.com/albums/u76/ ... 4ktrjr.jpg[/img]
[img
[img
Re: JTM45 Build
I have filed the "nib" down just enough so I can push it through. You can file it completely down and use a Bellville push nut like the lamp styles without the nib or even use an E clip of the appropriate size to pinch the indicator shaft.Littlewyan wrote:I've bought a Red Marshall 6V indicator lamp for the amp and the lamp has a little nib on it which pushes against the faceplate. Is there supposed to be a cut out for the nib? I vaguely remember the indicator on my 1987xl sticking out slightly on one side so maybe its just there to push against the faceplate.
http://www.valvestorm.com/6vIndicatorInstall
TM
- Littlewyan
Re: JTM45 Build
Thanks guys.
With regards to heater wires and high voltage secondary wires on a PT is it ok to cross them? Its just with how my PT is laid out the 6.3V heater secondaries have got to go across the high voltage secondaries to get to the first valve.
- JazzGuitarGimp
Re: JTM45 Build
My first guess would be "it's all AC, so it doesn't matter". But that's all it would be: a guess. I'd be very interested to know if there is the possibility of interference from someone in the know.Littlewyan wrote:Thanks guys.
- statorvane
Re: JTM45 Build
Mine is parallel to the 120 VAC in the black amplifier. Here's a photo: [img
768]http://i165.photobucket.com/albums/u76/ ... vzolvv.jpg[/img]
Pretty quiet amplifier. Frankly, it's the best one I've built.
- Littlewyan
Re: JTM45 Build
Yeah but it doesnt matter with the primaries. I'm sure it won't matter and the wires will be so long that I could re route them later if need be.
Re: JTM45 Build
statorvane, who did those very nice looking cabs for you? Yourself?
