It's walnut, sapele, and tiger maple. Need to put handle on and make back panel, and more finish work.
New 2204'ish Build
Re: New 2204'ish Build
Here is the new cabinet for this amp.
Man, that's Sharp!
Stunning cab Jeff.
The amp & cab are made for each other.
Great Work !
Great Work !
Why Aye Man
Need help. Can't decide which color faceplate. Help me decide please.
Faceplate-1 or Faceplate-2.
Beautiful cab!
Faceplate 3. Same as light accent lines.
Greg
Greg
Ok I may have to try that. I like wood.gktamps wrote:Beautiful cab!
Greg
Is #2 oxblood? It's a personal fave of mine and would go nicely with the wood. The piping (accent lines) looks much like #1 to me, sort of the standard Marshall gold?
I would say do a wood one but I think that would make it look too much like a Trainwreck.
Ok here is Faceplate-3.
Tiger Maple. May try a Plexi style Faceplate also, but I like the Maple.
Now the lettering?
Now the lettering?
Yes kind of, I used Photoshop to color and letter the first two Faceplates.sepulchre wrote:Is#2 oxblood? It's a personal fave of mine and would go nicely with the wood.
#3 is wood and is on the amp. Oxblood reminds me of an AC30 I like it also.
Thanks Bob, thought about doing Tolex but went with wood. I think it was the right choice.Bob S wrote:Stunning cab Jeff.
Great Work !
Why didn't I think of that??? Thanks Greg.gktamps wrote:Faceplate 3. Same as light accent lines.
Greg
How did you do those accent lines? Is that inlaid? Looks really fine.
Quite welcome, Jeff. Looks absolutely beautiful, and I would be proud to own that cabinet myself!
Hmm, typeface - so many choices. Sans serif, for sure, to start. Nothing too whimsical, comical or casual, but nothing stark, blocky or archaic. I'm thinking something with a slightly narrow aspect to keep the words tighter?
Your example is slanted, but I wonder if upright might work better with the right angles of the wood pattern. Opposing view from the wife; a semi-cursive like your example is a nice contrast to the right angles.
I'll bet your amp sounds as good as the cab looks.
Greg
Greg
Yes I inlaid maple in the front stripe also the top and bottom.sepulchre wrote:How did you do those accent lines? Is that inlaid? Looks really fine.
Had to bend the top and bottom pieces like bending guitar sides.
Border of front panel is 3/4" thick strip glued to edge.
Stunner. If Marshall had any brains they'd have issued a super special edition with a cab like that.
