[Question] Brownface Tremolo on V1
Fender Amp Discussion
Bombacaototal
Post by Bombacaototal »
Happy new year to all! May 2018 be an even better year!
I am struggling to remember which brownface amp had the tremolo on the cathodes of V1 tubes?
Anyone can fresh up my mind please? Thanks a lot!
sluckey
Re: [Question] Brownface Tremolo on V1
Post by sluckey »
Bombacaototal wrote: Mon Jan 01, 2018 12:21 pm I am struggling to remember which brownface amp had the tremolo on the cathodes of V1 tubes?
I don't think any brownface (6Gxx) amp ever had that type tremolo. The only Fender amps I recall that applied tremolo to V1 cathode was Bronco and Vibro-Champ (same as Bronco).
10thTx
Post by 10thTx »
Vibrolux 5e11 Are you thinking of a tweed amp and not brownface?
http://el34world.com/charts/Schematics/ ... _schem.pdf
With respect, 10thtx
sluckey
Post by sluckey »
That 5E11 uses half of V1 for the trem oscillator, but the trem signal is actually applied to the grids of the output tubes, not the cathode of V1.
10thTx
Post by 10thTx »
You're right! My error.
This one seems to tie into a cathode of V2 instead of V1. Maybe this would work for you?
5E9 Tremolux
Bombacaototal
That’s perfect! Thanks a lot for the help!
Bombacaototal
10thTx wrote: Mon Jan 01, 2018 2:06 pm
5E9 Tremolux
10thtx, I am just wondering of Magnatone had any design which was similar to this one where the Tremolo is on V1 cathodes?
sluckey
Post by sluckey »
I don't recall any Magnatones using that type of tremolo, but that's not to say that some of their cheaper models didn't. You can find that type tremolo on many Valco amps and other cheap amps.
Plenty of Supros used that tremolo. Here are a couple...
http://el34world.com/charts/Schematics/ ... 01690T.pdf
http://el34world.com/charts/Schematics/ ... ic_263.pdf
And the popular Marshall 1974 18 Watt amp...
Plenty more examples out there if you just look through some schematic libraries.
Bombacaototal wrote: Sat Jan 06, 2018 1:54 pm...I am just wondering of Magnatone had any design which was similar to this one where the Tremolo is on V1 cathodes?
Why Magnatone? If you are interested in their pitch-shifting vibrato, that is a very different technique.
didit
Post by didit »
Gibson had some designs on this line. For example this GA40T
Best .. Ian
sluckey
Post by sluckey »
didit wrote: Sat Jan 06, 2018 4:58 pm Gibson had some designs on this line. For example this GA40T
That amp uses a LDR to shunt the guitar signal at the wiper of the volume control.
didit
Post by didit »
Yes. There are others with without LDR that directly modulate.
Bombacaototal
sluckey wrote: Sat Jan 06, 2018 3:19 pm I don't recall any Magnatones using that type of tremolo, but that's not to say that some of their cheaper models didn't. You can find that type tremolo on many Valco amps and other cheap amps.
Thanks a lot Sluckey! I was looking for other alternatives for this type of circuit and these helped a lot.
Bombacaototal
I am thinking of implementing a switch on the Tremolux 5E9 tremolo, to be able to remove it completely from the circuit. Given the switch will be placed at the cathode it will need to handle DC. Any recommendations of a switch?
sluckey
Post by sluckey »
Use anything that will fit the chassis.
