Hi there, I'm on my first built, a 5F1 of course. I'm doing a bus grounding scheme a la Boot Hill's examples I found on the web. Everything seems relatively clear except for two points.
The wiring layout I am using (Triode) has a ground run from the Speaker Jack. Should this go to the power-ground bus or the pre-amp ground bus?
Also, I am installing a 500k pot next to the speaker jack to allow for dialing in a NFB mod. Where should I be grounding this pot?
Thanks!
5F1 Bus Grounding: where to ground speaker out?
Paul Nordin
Re: 5F1 Bus Grounding: where to ground speaker out?
The black 'ground' wire from the output transformer secondary should be grounded at the speaker jack's sleeve (ground) terminal.
I would ground the variable NFB pot to the preamp bus. That's where the 5F6A Bassman's Presence control is grounded.
Paul Nordin
Thanks. That's very helpful!robrob wrote:The black 'ground' wire from the output transformer secondary should be grounded at the speaker jack's sleeve (ground) terminal.
Why such a big value pot to test with, a 15k would be a better starting point in my mind?
Paul Nordin
I picked that for two reasons, firstly I read a posting from someone else who had used that value Pot for the same mod and really liked the results. So I started out thinking I would just use that. Secondly, that high value allows me for all intents and purposed remove NFB entirely by dialing it up.Stevem wrote:Why such a big value pot to test with, a 15k would be a better starting point in my mind?
I finished the amp this morning and it sounds fantastic, so I feel it was a good choice.
I also ended up taking the Speaker Jack ground back to the PT ground bus. And the amp is pleasantly quite, so all turned out well.
vibratoking
Glad you got it working.
Electronic equipment is designed using facts and mathematics, not opinion and dogma.
Paul Nordin
Demo of my Champ based build...
For anyone that might be interested, here is a demo we filmed of the amp.
Cheers
https://youtu.be/BPfQDySbz9o
Cheers
