I have installed the post phase inverter master Volume mod on a AB763,(Marshall type) (the 220k resistors are now variable)
Unfortunately the Amp goes into oscillation when the volume is increased.
Does anyone have any suggestions for fixing this?? I have used shield cables etc
regards Don
Fender Twin reverb Master Volume MOd
Ninguisdomesticus
Ninguis Musician
Re: Fender Twin reverb Master Volume MOd
Did you try switching the wires around yet?
dealer: allparts, weber, antique electronic supply
Are your shielded cables grounded at only one end?
nice
I would like to try that on my twin,Love to see the best way to mod it,ant pics?Good luck,Mikey
It's not difficult Mike. "Best" is probably personal preference. You can probably use an existing hole in the chassis (extension speaker jack, or ground switch e.g.), so no permanent damage.
