Brownface Potentiometers
Fender Amp Discussion
strat100
Re: Brownface Potentiometers
Post by strat100 »
It's obvious that the signal is getting mixed into both channels but finding it is being a problem for me, think that the problem is I am finding it hard to know exactly where the signal should be and where it shouldn't as I can't decipher the schematic of the vibrato part, any one up for drawing the signal trace through the vibrato part to help me?
Is the power amp working? You might try disconnecting the negative feedback, and/or lifting the end of the PI input cap (at the red arrow, which isolates the power amp from the preamp) and feeding signal in there.
sluckey
Post by sluckey »
sluckey
Post by sluckey »
Hey Martin, what is the name of the font you used in your marked up schematic? I like it.
EDIT... Never mind. I found the Bradley Hand font pretty quickly but it was just too thin in Visio. Using bold did not help. Then it finally dawned on me that you probably used a graphics program to insert the text. As soon as I inserted text through PSP I was able to change the stroke width and match your text exactly.
Yes Bradley Hand is correct. I'm not as sophisticated as you are. I do all of my sketching in PowerPoint :^)
sluckey
Post by sluckey »
Haha. Sophistication is relative and highly overrated. :wink:
The last time I needed that 10M RA pot I got it from TAD but now they don't list it.
strat100
Post by strat100 »
Thank you Gentlemen that is perfect will have a look and see what i can find later.
The power amp is working but the signal is louder on i side of the P.I
strat100
Post by strat100 »
Normal channel add audio and channel clean upto 220k mix resistor and o.oo1uf cap goes to pin 2 on v6 still clean this is where it goes pearshaped for me because on pins 1+3+6+7+8 its got the vibrato. Confused.com
sluckey
Post by sluckey »
strat100 wrote: Thu Feb 09, 2023 5:41 pm Normal channel add audio and channel clean upto 220k mix resistor and o.oo1uf cap goes to pin 2 on v6 still clean this is where it goes pearshaped for me because on pins 1+3+6+7+8 its got the vibrato. Confused.com
Just pull V2, V3, V4, and V5. This totally removes the VIB channel leaving just a simple one channel amp. Now get the normal channel working properly before putting those tubes back in.
strat100
Post by strat100 »
Just done that and its distorted ring modulated so going to lift the 0.05 cap and feed it direct to power amp
strat100
Post by strat100 »
So its in the power amp somewhere as lifted the 0.05uf cap and attached to the 0.001uf cap and sound still distorted, going to try lifting the feedback loop now.
strat100
Post by strat100 »
Lifted feedback loop and no change.Any ideas what i try next?
strat100
Post by strat100 »
Chased signal through power amp and its clean till it hits pin 3 on both power tubes :shock:
sluckey
Post by sluckey »
strat100 wrote: Thu Feb 09, 2023 6:33 pm Chased signal through power amp and its clean till it hits pin 3 on both power tubes :shock:
Probably not a good idea to connect a scope to pin 3 of the output tubes. Safer to connect to the speaker jack.
With no signal applied measure the voltages on pins 3, 4, 5, and 8 of both power tubes. What have you?
